Need a hand with ospf
I've been struggling with this for a bit now figured see if anyone could give me a hand I need the 2 pcs to ping I've added the file for you to check out
both your PC's did not have default gateways configured. Your routers did either not have OSPF configured at all, or the interfaces were using the wrong process ID and/or area. Find attached the revised, working file...
Thank you so much
