Need ACL/NAT help with new router
tbeardsley22
6 Replies 6
luis_cordova
Hi @tbeardsley22 ,
You have to specify your problem.
Not sure what happened but original post didn't show.
tbeardsley22
I have no clue what happened but none of it posted.  Here's the post:
Hi everyone.  First time posting as I'm just stuck.  My router/firewall skills are weak at best so I'm hoping for some insight.  We are coming from a Cisco 5510 to Cisco 5508-x.  Both are connected to the same downstream layer 3 switch.  I cannot for the life of me get routing figured out.  The Cisco 5508 attaches to a switch with a default gateway of 10.10.10.154 which is the inside interface of the old cisco 5510. There is also a static route to the new Cisco 5508 (172.16.1.10)inside interface for a vlan I'm trying to route.  Config is below but all I'm trying to do is get 172.16.30.0 network to route out public IP of 68.133.87.40 which is part of a block on Interface/1 on the cisco 5508.  What i have configured here doesn't allow any traffic to pass.  Logs show tcp connect messages and then it ends with 0 syn timeout after 30 seconds.  So what am I doing wrong? Thanks for any help!
ASA Version 9.10(1)
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 68.133.87.34 255.255.255.0
interface GigabitEthernet1/2
nameif inside
security-level 100
ip address 172.16.1.10 255.255.255.0
interface GigabitEthernet1/3
nameif DMZ1
security-level 75
ip address 192.168.2.1 255.255.255.0
no asdm history enable
arp timeout 14400
arp permit-nonconnected
arp rate-limit 16384
nat (inside,outside) source static CTX_VLAN30 CTX_Servers_Edge
object network obj_any
nat (any,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group pacs_access_in in interface DMZ1
route outside 0.0.0.0 0.0.0.0 68.133.87.1 1
route inside 172.16.30.0 255.255.255.0 172.16.1.11 1
Hello
Can you post what your acls look like?
Kind Regards
Paul
Sure here they are.  Thanks for any help!  The VLAN30 I'm trying to get to work is part of the Object-Group Inside_VLANS_Web_Allowed.
access-list inside_access_in extended permit ip object-group Inside_VLANs_Web_Allowed any
access-list inside_access_in extended deny ip object-group Inside_VLANs_Web_Denied any
ccess-list pacs_access_in extended permit ip object PACS_Proxy_Private object GE_PACS_Private
access-list pacs_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any object PACS_Proxy_Private object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit tcp any object CTX_VLAN30 object-group DM_INLINE_TCP_2
access-list outside_cryptomap_5 extended permit ip object-group Oppor_VPN_Hosts_Internal object-group Oppor_VPN_Hosts_External
object-group service DM_INLINE_TCP_2 tcp
port-object eq www
port-object eq https
And i miss-typed the inside interface of the old cisco 5510 is 10.10.10.154.  New 5508 is 172.16.1.10.
