Need HELP need a basic config for 891-fw
tony.kahi1
Community Member
Hello all newbie here, we need a basic config with internal wp0 activated. Ive read threads and tried some for 871w configs but cannot for the life of me get this to work.
Any help or basic sample config.
Scenario: STATIC IP FROM CARRIER
Heres what I have so far
enable secret xxxxxxxx
! Configure the DHCP pool to assign addresses to internal hosts
ip dhcp pool vlan1pool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
! Do not assign addresses 1 to 30
ip dhcp excluded-address 192.168.1.1 192.168.1.50
! This is the LAN facing interface of the 800 router. Used as gateway for PCs
interface vlan 1
ip nat inside
no shut
! WAN Interface
interface FastEthernet0
ip address 100.100.100.1 255.255.255.0
ip nat outside
no shut
interface  GigabitEthernet0
no shut
interface  GigabitEthernet1
no shut
interface  GigabitEthernet2
no shut
interface  GigabitEthernet3
no shut
interface  GigabitEthernet4
no shut
interface  GigabitEthernet5
no shut
interface  GigabitEthernet6
no shut
interface  GigabitEthernet7
no shut
interface  GigabitEthernet8
no shut
! Configure NAT. All internal hosts will be nated on the WAN interface
ip nat inside source list 1 interface fastethernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
! Configure static NAT for port redirection
ip nat inside source static tcp 192.168.1.10 80 100.100.100.1 80 extendable
ip route 0.0.0.0 0.0.0.0 100.100.100.2
line vty 0 4
password somestrongpassword
I take it its the Built in AP you want to configure.
to go to the AP you need to enter something like
"service-module wlan-ap 0 session"
this gets you into the AP and you configure from there.
Richard
