need help on BGP load balancing between 4 links
sohail161982
Hello everyone
I need some help regarding BGP load balance and failover. Here is my scenario. I am currently connected with two upstream provider with four physical interface for failover/redundancy. Now I need to configure loadbalance with failover between those pair of interfaces. To make my scenario more clear please see the attached picture.
"maximum-paths 2" will load-balance only your outbound traffic. the load-balancing will be towards only one ISP
In-bound load-balanccing can be acheived to some extend by
1.dividing your /21 subnet to two /22 and avertise it to both neighbors
2. for one neighbor add extra as-path using as-path prepedning for one subnet of /22
3. for the other neighbor, advertise the other /22 with as-path prepend
This will help only  if you have good amount of traffic to both subnets of /22
Thank you
Raju
7 Replies 7
Raju Sekharan
Hi Monirul
1. you have 2 links to each ISP. Are you going to have peering using single IP address for these 2 links? Are you going to use any bundling on these interfaces?
2. Are you going to receive complete routing table from ISPs or default-routes?
3. Do you have your own public AS and do you need to advertise your rnage of Public addresses to outside?
Raju
Hi Raju
Please find the answer inline.
---Yes i am using peering IP for all the individual link. That means i have four peer ip.
---No I am not using any bundling on these interfaces right now.
---- I am receiving default route only.
---Yes i have my own AS along with /21 IP and I advertise them as per requirement.
to load-balance outbound then simply configure maximum-paths 2 under BGP process
Regards.
Alain
Hi Alain
Thanks for your reply. I need to load-balance my inbound traffic. Will "maximum-paths 2" accomplish the task ? I need failover and load-balance both. Currently I am doing manual inbound load-balance with prefix-list.
no maximum-paths is only for outbound load balancing.
Regards.
Alain
Thank you
Raju
Thanks Raju its working. Initialy it was not working because of the prepending to same SP restriction on my upstram.
Thanks for your help.
Sohail
