Netflow configuration
adnane dakna
Level 3
Level 3
Hello  ,
I need some support in setting netflow in my 7600 Cisco router ,  I had specific trafic comes to my router  with identified ip-src and ip-dst , but I can't expect from which interfaces it comes , How can I configure netflow in global router to catch this trafic
Are you using Flexible NetFlow to configure the export?  You need to specify the interface in the FnF configuration
collect interface input
collect interface output
Contact plixer and they will help you with this.
