Netflow version 9 support
secureIT
Level 7
Level 7
Hi All,
Does Netflow version 9 supported in CISCO7606-S having RSP720-3C-GE module ?
Current version is adventerprisek9-mz.122-33.SRE8 and planning to upgrade to 12.3(11)T to support ip flow egress.
So kindly advice on this.
regards
SecIT
Julio E. Moisa
It should, Also please check this link in order to verify if the IOS supports netflow v9
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
From the attached screenshot of the Cisco Feature Navigator, when filtered with "Netflow V9 Export Format", could not see Cisco 7600 series router in the list.
Pls confirm if I have selected the right search field as "V9".
Pls find the below URL.
http://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/nfexpfv9.html#wp1069711
Feature Specifications for NetFlow Version 9 Data Export
Feature History
Release
Modification
12.0(24)S
This feature was introduced.
12.3(1)
This feature was integrated into Cisco IOS Release 12.3(1), and output of the debug ip flow export command was modified to show NetFlow version 9 information.
12.2(18)S
This feature was integrated into Cisco IOS Release 12.2(18)S.
Supported Platforms
Cisco 2600 series, Cisco 3600 series, Cisco 7100 series, Cisco 7200 series, Cisco 7300 series, Cisco 7400 series, Cisco 7500 series, Cisco 12000 series
I do not find Cisco 7600 series router here.
Rajesh
You are right, it's not explicit, investigating I found the following info, I think the last link does not work. It also supports netflow v9 for IPv6
Reference: http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/nde.html#pgfId-1075059
This chapter describes how to configure NetFlow statistics collection and NetFlow Data Export (NDE) on the Cisco 7600 series routers.
Note For complete syntax and usage information for the commands used in this chapter, refer to the Cisco IOS NetFlow Command Reference at this URL:
http://www.cisco.com/en/US/docs/ios/netflow/command/reference/nf_book.html
  • NetFlow version 9 is supported—See this publication:
Cisco IOS NetFlow Configuration Guide
  • NetFlow multicast support includes the NetFlow v9 export format feature. See this publication:
You do not need to configure multicast fast switching or multicast distributed fast switching (MDFS); multicast CEF switching is supported.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123_1/nfv9expf.htm
Check out this document, which states that 7600's don't support Netflow egress:
