Network Time on Cisco 801 ISDN Router
tpaprotny
I have a number of 801 ISDN routers on my network. If I lose power to these devices the internal clock time is reset to default when the device reboots. This causes a problem with my users because we have configured a time range for when the router can dial to connect.
Is there any way I can set an NNTP service that would provide the router with the correct time after a power outage. If there is how do I limit this to get time info 2 or 3 time per day.
7 Replies 7
tdrais
Level 7
Level 7
Sounds like the easiest way is add another time range that adds the default time to your permitted range. The router should then be able to connect using NTP to reset the clock. Once the clock is reset it would use the other time range. Not sure what the default clock is but they should be all the same for the same router and ios release.
Hi Many thanks for your reply.
I have checked the router and cannot see any NTP support, do I need an IOS upgrade
Current version is:
IOS (tm) C800 Software (C800-Y6-MW), Version 12.1(3)XG5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 08-Aug-01 08:49 by ealyon
Image text-base: 0x000EE000, data-base: 0x00655000
ROM: TinyROM version 1.4(1)
801_Housing_Tarbert uptime is 10 hours, 52 minutes
System restarted at 05:52:36 UTC Mon Dec 11 2006
System image file is "flash:c800-y6-mw.121-3.XG5"
Wilson Samuel
Level 7
Level 7
There are plenty of NTP Servers which you can configure as an NTP Server for your Router, and then every time the Router reboots, it will check the time from the NTP Server and synchronize the same with it.
You may use some of the servers from this Website
http://ntp.isc.org/bin/view/Servers/NTPPoolServers
Moreover, please be advised that some of the Servers may require prior authorization before you point your Router to them.
Secondly the configuration may be something like this:
ntp server x.x.x.x
And you can check the configuration as below:
sh ntp association
sh ntp status
HTH,
Please rate if it helps
Wilson Samuel
Hi Many thanks, have tried this and am getting the following:
Tarbert>sh ntp status
% Invalid input detected at '^' marker.
Tarbert>sh ntp association
Type show SNTP
Some of smaller cisco routers did not support full NTP. You may also need something like IPPLUS IOS you would need to read the release notes to see.
Ah Ha! thats it, got it now, many thanks for your help.
Please be advised that, its always best to use the enable mode to get a valid response.
This command works only in the Priviliged mode.
Wilson Samuel
PS: Please rate if it helps.
c2c-stlo2mo#sh ntp stat
Clock is synchronized, stratum 3, reference is 10.120.6.133
nominal freq is 250.0000 Hz, actual freq is 249.9976 Hz, precision is 2**19
reference time is C9283975.FDEF1942 (20:09:25.991 GMT Mon Dec 11 2006)
clock offset is 5.5282 msec, root delay is 85.27 msec
root dispersion is 38.85 msec, peer dispersion is 5.92 msec
c2c-stlo2mo#
c2c-stlo2mo#sh ntp ass
address ref clock st when poll reach delay offset disp
*~10.120.6.133 18.26.4.105 2 594 1024 377 68.4 6.20 4.9
+~10.220.8.150 192.43.244.18 2 707 1024 377 59.4 4.86 20.2
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
c2c-stlo2mo#
