All,
Attaching below the diagram of the network which I am trying to configure, the configuration is as follows: An L3VPN from a Service Provider has been configured and working fine, we are connecting to the Provider managed CE through a 2811 routers, which is connected to two 3750s with L3 functionality, this is further connected to a pair of two stacked 3750s with only L2 functionlity. On this L2 switch stack we have configured 4 Vlans - 2,3,4 and 5, which we want to interconnect with network in Country B across the L3 VPN.
In Country B, the setup is as shown, where "XY" are connected to 3750s country B via IP interfaces, and so on...
We are using only static routing... Vlan IP interfaces (gateways) are created on 3750s L3 country A, L2 country A and L3 Country A are connected thru Trunked interfaces..
Question is, why are we not able to make the Nodes in Country B communicate with Nodes in Country A...
Also I want to configure a IPSec tunnel as a backup for the L3VPN, suggest on that too...
Kindly write back for further clarifications...
Nakul Kumar
