no menu command
tmanville
Community Member
I've got a ISR4451-X/K9. IOS is isr4400-universalk9.16.03.07.SPA.bin. I'm trying to configure a terminal server but when i try this is my message: terminal-server(config)#menu ? % Unrecognized command terminal-server(config)#menu ^ % Invalid input detected at '^' marker. Any assistance would be appreciated. thanks...
6 Replies 6
Georg Pauwen
I think you need the appxk9 license on this platform for the 'menu' command to be available. Which one do you have installed, what is the output of:
sh lic
Index 1 Feature: appxk9
Period left: Life time
License Type: RightToUse
License State: Active, Not in Use, EULA accepted
License Count: Non-Counted
License Priority: Low
did you reboot the router after installing the license ?
The global config command 'license boot level' might be required as well...
Menu Command has moved to IP Base with 16.9 IOS-XE release and later. Please use latest rebuild or more preferably use 16.12 if Smart Licensing is OK
would you be so kind as to outline the steps for me? thanks...
thanks...i'll give this a shot.
