01-03-2009 09:17 AM - edited 03-04-2019 03:18 AM
Hi ALL:
Happy New Year
I am getting this error when trying to copy the run to start up could any one explain the reason.
Router#cop
Router#copy run
Router#copy running-config st
Router#copy running-config startup-config
Destination filename [startup-config]?
startup-config file open failed (No such file or directory)
Router#
Router#sh star
Router#sh startup-config
Using 1821 out of 196600 bytes
%Error opening nvram:/startup-config (No such file or directory)
Router#
Router#
Router#copy startup-config running-config
%% Non-volatile configuration memory invalid or not present
Router#
Router#sh flash
Router#sh flash:
-#- --length-- -----date/time------ path
1 1821 Dec 28 2007 00:48:26 +00:00 sdmconfig-18xx.cfg
2 861696 Dec 28 2007 00:48:50 +00:00 es.tar
3 1164288 Dec 28 2007 00:49:16 +00:00 common.tar
4 1038 Dec 28 2007 00:49:40 +00:00 home.shtml
5 113152 Dec 28 2007 00:50:04 +00:00 home.tar
6 20570916 Feb 23 2008 07:30:52 +00:00 c1841-spservicesk9-mz.124-16b.bin
9203712 bytes available (22728704 bytes used)
Router#
Router#
Router#sh ver
Cisco IOS Software, 1841 Software (C1841-SPSERVICESK9-M), Version 12.4(16b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 19-Dec-07 23:28 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 47 minutes
System image file is "flash:c1841-spservicesk9-mz.124-16b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FHK115225UY
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Chao
Vishwa
01-03-2009 03:16 PM
Vishwa
This is a very unusual symptom. Would you post the output of show file system from this 1841.
Rick
01-03-2009 11:04 PM
Vishwa,
This case is happend due to buffer issue in NVRAM.We have to clear NVRAM,so erase the NVRAM and try ..it will work..
Command - Router#erase nvram:
after clearing the NVRAM don't restart the router without copy the config to start-up.
STALIN P
01-04-2009 08:51 PM
Thanks Guys ,
For the reply issue is resolved.
I dont know why it was happenning i did the same step after reload and it worked .
Crazy Ciso.
Chao
Vishwa
01-05-2009 01:42 AM
Do
#format nvram:
and try
01-05-2009 05:12 AM
Vishwa
Thank you for posting back and telling us that the issue was resolved when you reloaded the router. It makes the forum more useful when people can read about a problem and can read what was done that resolved the problem.
Rick
