not booting 3745 router
iqbalkhan
I have a 3745 router with CE Module
when I start power on , then after the message the router not boot. same result arise after without CE module also.
so what is the problem ?.
Bootstrap version 12.2 (8r)T2
program load complete, entry point: 0x80008000, size: 0x1172120
Self decompressing the image : #################################################
########################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0002F7 0X005F3C00 C3745 Mainboard
0X00280000 OIR memory
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00B787B0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 9 percent iomem. [12Mb/128Mb]
-----in here stop not booting
thanks
Biplob
5 Replies 5
lgijssel
Level 9
Level 9
Did you execute an IOS upgrade when this started to occur?
Leo
lgijssel
Level 9
Level 9
Leo
Roberto Salazar
Level 8
Level 8
Make sure the memory module is seated properly. If memory had been confirmed, it is likely the IOS had been corrupted.
Thanks. I check it.
hi
i replace the RAM slot but still sam eproblem and also IOS change.
biplob
