number of vrfs supported in MPLS/VPN
nishantmj
How many vrf's can i make using ospf as PE-CE routing protocol.The platform is 7609 router.and using iBGP as PE-PE routing protocol.
Giuseppe Larosa
Hello Nishant,
in first implementation of OSPF as PE-CE the limit was counted against the max number of OSPF processes on the box and was in the order of 30.
A successive implementation has removed this limit for VRF OSPF instances.
see
http://www.cisco.com/en/US/partner/docs/ios/iproute/configuration/guide/irp_ospf_un_sw_vrfs_ps6017_TSD_Products_Configuration_Guide_Chapter.html#wp1054091
or
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ospf_un_sw_vrfs_ps6017_TSD_Products_Configuration_Guide_Chapter.html#wp1054091
if you have an IOS >
12.2(18)SXE
This feature was integrated into Cisco IOS Release 12.2(18)SXE.
12.2(27)SBC
This feature was integrated into Cisco IOS Release 12.2(27)SBC.
You should be fine
Hope to help
Giuseppe
Thanks Giueseppe.
I have gone through the links and found one ambigious statement."Only 32 processes per VRF can be supported. For different VRF processes, there is no limit. "
Can you elaborate on this statement?
Appreciate your help
