OSPF - Design Question
agent2007
Hi All,
I am working on a design at the moment and would like to run it past you OSPF experts as its not a routing protocol I get to work with really.
The Scenario is I have a Primary Data Center and 8 Remote offices around the globe.  All of the locations have an ISP connection and an MPLS connection.  All the remote offices connect to the data center for services but they should also have the ability to connect to each other.  I am going to use a Hub and Spoke Topology for the VPNs and allow routing between locations.  I plan on having an IPSEC VPN between each office to the data center across both the MPLS network and backup via the ISP.  I plan on using OSPF for seemless failover if the primary link goes down.
My question is will I be OK to do all of this in one Area?  So Area0 for all of this?
Thanks a lot
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might use just a single area.  What's you expected network stability?  If you expect instability, you might use one area per remote office (and area zero for DC) to mitigate topology flaps from other OSPF areas.
