OSPF different asbrs and default route for different areas
Hi everyone
Is it possible to have two asbrs on two areas which advertising default route to their areas. for example R1 is in area 0 and has default route to internet and advertise default route to area 0. R2 is in area 1 and advertise default route to area 1 and these areas doesnt receive any default route from each other.
how can I do that?
Hello @ectssamsectssams5825 ,
make area 1 an NSSA area then also have the R60 to advertise an LSA type 7 with no-propagate option so that ABR will not translate it to area 0
Hope to help
Giuseppe
6 Replies 6
do you mean ASBRs or ABRs ? Post a schematic drawing showing what you want to accomplish.
I mean Asbr.
default route for area 0 R61
default route for area 1 R60
Hope to help
Giuseppe
config
default-information originate metric-type 1
this make internal in Area 0 select the default toward ASBR area 0
and internal in Area 1 select the default toward ASBR area 1
metric-type 1 cost is equal to sum of all link cost to ASBR.
but if R61 fails, area 0 use R60 as default route and whole traffic goes to R60
you will get redundancy also.
but NSSA is complete isolate the area default gateway.
