OSPF in VRF goes down ”Shutdown”
Dhari Kh Abedula
I have VRF name TEST  tied with Tunnel interface and this Tunnel using for DMVPN .
I used OSPF in same VRF as route protocol
I add one commands under OSPF 1 VRF TEST
The command was ”redestrubution eigrp 123 subnet” To test something. After few minutes I delete this command by using
”No redestrubution eigrp 123 subnet”
After deleting command the whole OSPF went Down. I check the add under Ospf domain ” Shutdown ”!
it is very strange to me!
any one have the same problem before ?
It was ASR 1000 Router .
Router ospf 1 vrf TEST
exit
exit
Show run | Section OSPF
Shutdown
exit
13 Replies 13
DMVPN means hub and spoke...can you post the full configs of both ?
Francesco Molino
You're saying that just doing no redistribution of eigrp under ospf added the command shutdown?
What ios version are you using?
Can you post a detailed configuration regarding your interfaces and routing protocols?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Yes, this is what happens to me , I will check the module and update the question .
Thanks for you help ..
The original post tells us that
and then the original poster removed that command. So now the OSPF section has only the router ospf command and no other command indicating any interface or any action. I am not surprised that in that condition the protocol would be shutdown. It has nothing to do and no reason why it should be active.
Rick
Rick
Hello
here I go again with assumption but “if” ospf is applied at an interface level then removing the redistribution from the ospf stanza should not shut down the process?
Kind Regards
Paul
Paul
I agree with you about these pesky assumptions. You assume that perhaps there was an interface statement enabling OSPF. I assumed that the original post was literally true that there was only a single OSPF command. And neither of us knows for sure what the situation really is. So the best answer to the original poster is that we need more information to be able to give good answers to the question.
Rick
Rick
I still have Networks running in this VRF OSPF Domain when the the OSPF goes shutdown .
Yes there is ospf config under Tunnel interface, as I mentioned the router is DMVPN Hub .
it is ospf under tunnel interface config .
Did you mean it is normal goes down if there is no ospf config under interface mode ?
For me, this isn't normal. I tested with CSR1000v and other platforms with IOS-XE (but not ASR1k).
I had eigrp and ospf configured. When I remove redistribute eigrp, the ospf process doesn't go down (shutdown mode).
What's your exact config? and what version are you using?
Can you configure back the ospf, make sure everything works fine and then remove the redistribution eigrp into ospf to see if it goes back in shutdown mode?
Francesco
I using OSPF With VRF , And the issue router ver as below .
R01#sh version
Cisco IOS XE Software, Version 03.16.06.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 24-Jul-17 20:24 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
R01 uptime is 1 year, 13 weeks, 4 days, 18 hours, 21 minutes
Uptime for this control processor is 1 year, 13 weeks, 4 days, 18 hours, 22 minutes
System returned to ROM by reload at 06:44:35 CDT Tue Sep 12 2017
System restarted at 16:08:07 CDT Tue Sep 12 2017
System image file is "bootflash:asr1001x-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: adventerprise
License Type: Permanent
Next reload license Level: adventerprise
cisco ASR1001-X (1NG) processor (revision 1NG) with 3728371K/6147K bytes of memory.
Processor board ID FXS1904Q2PC
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6688767K bytes of eUSB flash at bootflash:.
This is an old version. When you have this ospf process shutdown, do you see any logs?
I'll try to get one downgrade and test that but in the meantime, can you maybe upgrade it with a recommended version and try again?
Francesco
There is log show my the OSPF Dwon only exactly like some one put shadwown on it..
can you share these logs please?
Francesco
