Ospf issues or what else?
Galileo59
Visitor
I have this network exercise but I found several problems, I can not access to HTTPS and FTP server, when I ping it blocks at the gateway. I need also to create a VPN between R1 and R4, I never did that before.. Any help much appreciated!
I attached the pkt file and my conf in a zip file
I opened your file, it contains many mistakes. The NAT configuration is incomplete, and the VPN is configured wrong. Use the file attached, which is a revised version of the one I sent you earlier, including the NAT part.
14 Replies 14
 You did very will on the config. You made a simple mistake when configuring the servers. You put them ip address 10.20.0.1/30 and on the gateway you put 10.20.1.254/30 which means that the Server and the gateway was not on the same network.
I changed the server´s IP address to 10.20.0.253 and 10.25.0.253 and it  is working.
Thx a lot Flavio! How did I miss this? I'll focus more ...
My gateway was 10.20.0.254 and 10.25.0.254
in order to keep the configurations consistent, you can also change the subnet masks of the Vlan subinterfaces on R4 to /24 addresses. That would make sense in the 'real' world also. Then you only need to change the subnet mask on the hosts, and keep the original IP addresses.
For the VPN, you cannot use the 2811 routers, as those don't support IPSEC in Packet Tracer. You need to use 4331 routers. In the attached file, I replaced the 2811 routers with 4331 routers. The configurations are identical except obviously for the VPN part (highlighted in bold). Attached the revised file including the VPN.
R1#sh run
Building configuration...
Current configuration : 1587 bytes
version 16.6.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip cef
no ipv6 cef
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 5
crypto isakmp key cisco123 address 10.3.0.1
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto map CMAP 10 ipsec-isakmp
set peer 10.3.0.1
set transform-set TS
match address VPN_ACL
spanning-tree mode pvst
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.50
encapsulation dot1Q 50
ip address 172.16.50.254 255.255.255.0
interface GigabitEthernet0/0/0.55
encapsulation dot1Q 55
ip address 172.16.55.254 255.255.255.0
interface GigabitEthernet0/0/1
ip address 10.1.0.1 255.255.255.252
duplex auto
speed auto
crypto map CMAP
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
redistribute static subnets
redistribute connected subnets
network 10.1.0.0 0.0.0.3 area 1
ip classless
ip flow-export version 9
ip access-list extended VPN_ACL
permit ip 172.16.50.0 0.0.0.255 10.20.0.0 0.0.0.255
permit ip 172.16.55.0 0.0.0.255 10.20.0.0 0.0.0.255
permit ip 172.16.50.0 0.0.0.255 10.25.0.0 0.0.0.255
permit ip 172.16.55.0 0.0.0.255 10.25.0.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
R4#sh run
Current configuration : 1536 bytes
version 16.6.4
hostname R4
ip cef
no ipv6 cef
encr 3des
hash md5
group 5
crypto isakmp key cisco123 address 10.1.0.1
set peer 10.1.0.1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.20
encapsulation dot1Q 20
ip address 10.20.0.254 255.255.255.0
interface GigabitEthernet0/0/0.25
encapsulation dot1Q 25
ip address 10.25.0.254 255.255.255.0
ip address 10.3.0.1 255.255.255.252
duplex auto
speed auto
crypto map CMAP
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 4.4.4.4
network 10.3.0.0 0.0.0.3 area 2
ip classless
permit ip 10.20.0.0 0.0.0.255 172.16.50.0 0.0.0.255
permit ip 10.25.0.0 0.0.0.255 172.16.50.0 0.0.0.255
permit ip 10.20.0.0 0.0.0.255 172.16.55.0 0.0.0.255
permit ip 10.25.0.0 0.0.0.255 172.16.55.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Galileo59
Visitor
Hello Georges,
Still problems, I can not ping vpn from 172....thx for your help
I can ping from e.g. 172.16.50.1 to 10.20.0.1 and 10.25.0.1, and vice versa. From which source IP address to which destination IP address can you not ping ?
Galileo59
Visitor
I can't ping from 172.16.50.1 to 10.20.0.1 or 10.25.0.1 but I can ping from 192.168... to 10.20.0.1 or 10.25.0.1 .
I need to do the opposite
I  can't ping from  172.... to 8.8.8.8 but i can from 192.168..... I have noclues...
Could you check my conf? I don't see where is the mistake
172.16 need to access 10.20 and 10.25
10.20 and 10.25 can not access to other networks nor 8.8.8.8 except 172.16 through vpn
192 and 172  need to access to Internet 8.8.8.8
ping works here (see image attached). I'll check your file...
Hello
thx for your help cause I'm really confused, I think it has to do with the ACL but I 'm mixing it so badly..
The ACL was one of the things that were wrong. Did you open my file ? It contains the correct configs...
Dear Georg,
Thank you so much, I made quite significant errors indeed, I need to practice more ACL and Nat rules, it is not in me yet..
Best regards,
practice makes perfect, you are definitely on the right track. The VPN stuff can be a bit confusing, especially in combination with NAT, but once you figure it out, it all starts to make sense...
