ospf redistribution command
tom_chan
Community Member
When we update the ospf redistribution command, should we completely remove the existing ospf redistribution command and then add the new command as below?
router ospf 100
router-id xx.xx.xx.xx
redistribute odr metric 1 metric-type 1 subnets                            <-- line 1 (remove)
redistribute odr metric-type 1 route-map ROUTEMAP subnets   <-- line 2 (newly add)
Or we simply type in the new command (line 2) without removing the existing one (line 1)?
Will the different model of Cisco routers behave differently when updating the ospf redistribution command?
We are using C3845 router.
aaron.conaway
Community Member
In my experience, when you add to the redistribution (like you did above), it will take the new settings.  I'm sure this is done intentionally so that there's not some length of time where the routes won't be redistributed at all while you type the new command.
Related : When you try to negate the redistribution, you have to be more careful.  If you do a "no redistribute odr <YOUR FULL LINE>", then only the details of the redistribution will be removed.  You have to do a "no redistribute odr" to remove it completely.  Here's some output from one of my lab routers showing what I'm talking about.
R3(config-router)#redistribute odr metric-type 1 route-map RM subnets
R3(config-router)#do show run | section ospf
router ospf 100
log-adjacency-changes
redistribute odr metric 1 metric-type 1 subnets route-map RM
R3(config-router)#no redistribute odr metric-type 1 route-map RM subnets
router ospf 100
router ospf 100
I don't believe this is platform specific. If there are differences, it would be between IOS versions or trains.  Someone should correct me if I'm wrong here.
-- Aaron
niluka senevirathna
Community Member
Hi Chun,
Yes. you have to remove the old command if your intention is to replace the old command with new one.  however in live production please insert the new command and then remove old entry.
Please refer below link for more information about Redistributing
Redistributing Routing Protocols - Cisco
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/8606-redist.html
Hope this helps
Niluka
aaron.conaway
Community Member
router ospf 100
router ospf 100
router ospf 100
-- Aaron
