OSPF Route Selection
deep.blue
Hi- I have situation where I will be running OSPF and will be recieving routes on one interface redistributed from BGP so these will be OSPF External Type 2 routes - on another interface I will be recieving routes in OSPF so these will be "intra area".
My question is how I do have the external E2 routes installed in preference to the intra area ones ? Ie the external routes are to be preferred while the intra area ones are back up.
21 Replies 21
No! That's precisely the point! I could not change the OSPF route arbitration by using AD. My original posting was wrong.
Kevin Dorrell
Luxembourg
Kevin
I am glad that you worked it out in the lab. That is frequently the best way to find what is really happening. The idea that you suggested is quite logical and appealing. But it is not the way that OSPF works.
Rick
Rick
Rick,
so what is the final process to get it done i am still in confusion?
regards
Devang
Devang
There is not a process that will get an OSPF external route preferred over an internal route. The closest that you could get would be to redistribute the internal routes. Then by controlling which are E1 routes and which are E2 routes you could control which route is preferred.
Rick
Rick
Rick,
thanks for clerification!!!
regards
Devang
Hi all,
Thanks for all your work in clarifying this for me. It is as I expected but sometimes the information is a little cryptic. I will now have in investigate another solution.
Pete
hello
to answer your initial question, you should investigate these 2 ideas :
-having 2 OSPF processes (this time playing with AD ;) )
-if you're using MPLS/VPN and you're using OSPF as PE/CE protocol, you should consider the use of sham-links
bye,
Etienne
