Packet Tracer Document Support
LM5000000
Visitor
I am currently in the process of creating a network on packet tracer for school work, however I have got to the testing stage and I have came across some errors which I can't seem to fix.
A few errors include;
- Link between RA and York House is down due to the link being disabled
- Link from York House to Liverpool Street (via tunnel) seems to not work
- Link for public network to other links doesn't work
All different network areas can't connect to each other when they need to but I also need to include ACLs which have been included in the configurations.
Would someone please be able to help me sort my connections that are not working.
Kind regards, Luke
Martin L
PT activity says it's solved or completed 100% so not sure if there are issues. are there?
all access to CLI is locked; how do u access the devices ? by telnet ?
Regards, ML
**Please Rate All Helpful Responses **
The activity itself has been completed but I am trying to add more to the network and as previously mentioned the connection don't all work.
To access the devices a console cable is connected from the admin laptop to the device you're trying to connect to.
Regards, LM
