Packet Tracer IPv6 routing
Hello everyone!
I'm new to the forums, so I'm in your care :)
I'm in a bit of a pinch, you see, I'm trying to get a network working with only IPv6, thus far I've been able to give everything their respective IPv6 addresses but I can't seem communicate between 2 routers on a copper crossover connection. The file has been added so if you could take a look, I'd appreciate that a bunch! I've tried using RIPng but whenever I use "show ipv6 route"nothing will be labeled as R...
The file has been labeled as jpeg due to the fact that the forum won't accept the format .pkt
Just rewrite the extension from .jpeg to .pkt, packet tracer will be able to work with it
raJdPEM
Harold Ritter
The only two IPv6 addresses I see in your diagram, are the 2001:db8:aaa:a::1/64 and 2001:db8:bbb:b::1/64 and seem to be both configured on the link between the two routers. These addresses are not part of the same subnet (first 64 bits are different), which is probably why you are having issues. Can you ping from one router to the other using the link local address?
for the sake of simplicity, I have reconfigured your network for IPv6 only, have a look at the config for reference...
