parser config cache interface
rajivrajan1
Level 3
Level 3
A 7200 with huge configuration :-(, its taking lot of time to see the running config and the cpu shoots up every time.
So planing to parser config cache interface
but some clarifications required
1. in whihc memory config will be stored ?
2.what are the other processes will get affected if memry is full ?
3.will the command warn me if there is not enough memory ?
if i have a config of 7034264 bits and 2194760 bits free in nvram - can i do this ? will it affect the production ?
