PAT problem
andrew005
I need all users of Network 1 to be able to access the Internet (connect to the Internet server). And I need to be able to connect to the corporate server from the "external network". I used the following commands to ensure this, but for some reason nothing worked. Please help.
SW0
Switch(config)#interface FastEthernet3/1
Switch(config-if)#switchport trunk allowed vlan 1,10,20
Switch(config-if)#switchport mode trunk
Switch(config)#int fa2/1
Switch(config-if)#switchport access vlan 10
Switch(config-if)#switchport mode access
Switch(config-if)#switchport port-security
Switch(config-if)#switchport port-security maximum 2
Switch(config-if)#switchport port-security mac-address sticky
Switch(config)#int fa1/1
Switch(config-if)#switchport access vlan 20
Switch(config-if)#switchport port-security maximum 1
Switch(config)#int fa0/1
Switch(config)#int fa3/1
Switch(config)#int fa4/1
Router0
Router(config)#interface FastEthernet1/0
Router(config-if)#ip address 192.24.40.1 255.255.255.252
Router(config-if)#ip nat outside
Router(config-if)#duplex auto
Router(config)#interface FastEthernet0/0
Router(config-if)#no ip address
Router(config)#int fa0/0.10
Router(config-subif)#encapsulation dot1Q 10
Router(config-subif)#ip nat inside
Router(config-subif)#ex
Router(config)#int fa0/0.20
Router(config-subif)#encapsulation dot1Q 20
Router(config)#ip access-list standard FOR-NAT
Router(config-std-nacl)#permit 192.168.18.0 0.0.0.255
Router(config-std-nacl)#permit 172.21.0.0 0.0.0.255
Router(config-std-nacl)#ex
Router(config)#ip nat inside source list FOR-NAT interface fa1/0 overload
Router(config)#ip nat inside source static tcp 192.168.18.6 80 199.24.40.1 80
2 Accepted Solutions
andrew005
Add new version. Who can help me and write commands, that help solve this problem?
andrew005
5 Replies 5
andrew005
@Flavio Miranda can u help me pleace?
M02@rt37
Hello @andrew005
On interface Fa0/0.10 and 0/0.20 you don't configure IP adresses...Gateway of vlan 10 and 20...
https://www.ciscopress.com/articles/article.asp?p=3089357&seqNum=5
Best regards
andrew005
The IP address is configured. But router0 and router1 cannot communicate with it properly and cannot initialize the connection between the PC and the Internet server.
andrew005
andrew005
new one
