Pause input
Is it ok if you see an increment on the pause input counter? Does it affect packet delivery from one site to another?
Here's what i got from previous discussions.
An increment in pause input counter means that the connected device requests for a traffic pause when its receive buffer is almost full. Common Causes: This counter is incremented for informational purposes, since the switch accepts the frame. The pause packets stop when the connected device is able to receive the traffic.
Description: The number of times the receiver hardware was unable to hand received data to a hardware buffer.Common Cause: The input rate of traffic exceeded the ability of the receiver to handle the data.
Common Causes: This includes runts, giants, no buffer, CRC, frame, overrun, and ignored counts. Other input-related errors can also cause the input errors count to be increased, and some datagrams can have more than one error. Therefore, this sum cannot balance with the sum of enumerated input error counts
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Pause frame will impact packet delivery, if they are generated and the other side "honors" them (i.e. actually pauses).  Impact might be less adverse if the alternative is lost of frames.  (NB: enhanced Ethernet supports different classes that can be paused independently.)
I'm unsure whether an incrementing counter just counts any received pause frames, or whether the receiver also has to honor them.
Joseph W. Doherty
Disclaimer
Posting
