Per User, Per Session based QoS
ashish.sehgal1
I want to assign 50 Kbps bw to any user attempting to access FTP servers in the DC.
Key word is:
Per User Per Session
Can we do it in CE router?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Most Cisco platforms don't directly support per-user/per-session rate limiting unless you define a policy for each user's IPs (which is a possible solution if we're only dealing with a hundred or so users).
6500s offer Microflow policing, which if you have that hardware, might be an option.
PS:
BTW, a possible alternative might be to use QoS to deprioritize FTP traffic to/from your DC FTP servers.  Such a QoS policy allows such traffic to use all available bandwidth, but such consumption won't be adverse to more critical traffic.
Ashish,
Preferably I will never do that, you might be wasting your bandwidth inorder to achieve it.
It should be only required if all your users do FTP all the time. Now, again putting FTP is least priority queue is a smart solution, because you if at a time your whole pipe is empty or using very less traffic, then FTP will get more.
If your connection is chocked you will use only least assigned to FTP.
