PIX how to break failover from HA
vadalisri
I have 2 pix 525 in High availability A/A mode and I have disconnected failover cable with 'no failover' on both firewalls .
Problem : Active firewall is working fine
but standby firewall (which is now indpendant)is not active and unable to utilize functionality. With 'failover active' command the standby unit is becoming active but limited in functionality. On reloading this firewall it not becomning active.
Any suggestions please
regards
Kaushik Vadali
a.alekseev
Level 7
Level 7
what are you going to do with the second?
could you show the output "sh ver"?
- This is show version
- I want to use second pix for a different process altogether independantly
Cisco PIX Firewall Version 6.2(2)
Cisco PIX Device Manager Version 2.1(1)
Compiled on Fri 07-Jun-02 17:49 by morlee
BSNL up 6 hours 14 mins
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.5
0: ethernet0: address is 000b.be09.b92f, irq 10
1: ethernet1: address is 000b.be09.b930, irq 11
2: ethernet2: address is 0002.b3d6.c184, irq 10
3: ethernet3: address is 0002.b3b9.7540, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 8
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This machine is licensed to run in failover secondary mode only
