Policy based routing or not
kapydan88
Level 4
Level 4
Hello for everybody.
We are going to install new ASA in one of the offices - current scheme in attach. But before installing, i would like to make sure that all the new settings are working. For these purposes, i plan to create a test vlan 100 (192.168.100.0 / 24) and use the PBR to install the internal interface of the new asa for nat from this vlan.
Is this correct way use PBR for these purposes?
Basic settings from the router below.
ISR#sh run | s ospf
router ospf 1 vrf office
redistribute connected subnets
default-information originate always
ISR#
ISR#sh run | i 0.0.0.0 0.0.0.0
ip route 0.0.0.0 0.0.0.0 1.2.3.4 external ip of ISR
ip route vrf office 0.0.0.0 0.0.0.0 10.10.20.2 current interface old asa inside for nat
ISR#
Hello
You don’t even need to create a access list as it looks like you wish to policy route all of the new subnet 100 towards the ASA, you could also apply some resiliency to the policy route in case the link to that asa fail or the next hop is unreachable and you wish to failover to the other ASA next hop however in the interim the below config is all what you need to do for basic policy routing
conf t
route-map PBR
set ip next-hop 10.10.10.2
int gig0/0/0.100
ip policy route-map PBR
Kind Regards
Paul
6 Replies 6
Jon Marshall
I can't work out how the first default route relates to your diagram but in answer to your question yes PBR can be used to test before you go live.
Are you asking for help with the PBR configuration ?
Jon
Thanks for answer.
First default route, which without any vrf, there is because, on this router comes a pair of gre tunnels. A default route in the vrf office - for nat in this office.
In this case the procedure should be something like this.
1) Create sub interface on the ISR router
interface GigabitEthernet0/0/0.100
encapsulation dot1Q 100
ip vrf forwarding office
ip address 192.168.100.1 255.255.255.0
2) Create acl
access-list extended vlan100
permit ip 192.168.100.0 0.0.0.255 any
3) Create PBR and set next hope 10.10.10.2 - inside interface of new ASA.
That should work fine.
Any problems let us know.
Jon
and im not sure about need to implement this PBR to the subinterface
ip policy route-map <name>
Yes, you need to create the route map and then apply that route map just as your configuration suggests.
Jon
Hello
conf t
route-map PBR
int gig0/0/0.100
Kind Regards
Paul
