Possible NAT issue
ojasvi.bansal
Hello All,
I use a 2611XM to route voice traffic. I use two ISPs for failover. I use IP SLA to track the interface and do a failover. Here's the configuration.
track timer interface 5
track 123 rtr 1 reachability
delay down 15 up 10
track 345 rtr 2 reachability
delay down 15 up 10
interface FastEthernet0/0
ip nat inside
interface FastEthernet0/1
ip address 182.65.23.52 255.255.252.0
ip nat outside
interface Dialer1
ip address negotiated
ip nat outside
ip route 0.0.0.0 0.0.0.0 182.65.23.1 track 123
ip route 0.0.0.0 0.0.0.0 Dialer1 5
ip access-list extended NAT
permit ip 192.168.0.0 0.0.0.255 any
ip nat inside source route-map CABLE interface FastEthernet0/1 overload oer
ip nat inside source route-map DSL interface Dialer1 overload oer
ip sla 1
icmp-echo 182.65.23.1 source-interface FastEthernet0/1
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 4.2.2.2 source-interface Dialer1
timeout 1000
threshold 40
frequency 3
ip sla schedule 2 life forever start-time now
route-map CABLE permit 10
match ip address NAT
match interface FastEthernet0/1
route-map DSL permit 10
match interface Dialer1
The problem is that any time an ISP goes down and the other ISP become primary path, I have to clear NAT statement from the router and reboot the phone. I am using an Asterisk based IP PBX as Call Manager and Linksys phones.
Any help on this would be highly appreciated.
Thanks and Regards
OJ
rais
Level 11
Level 11
Have you tried setting timeout seconds for NAT to a lower value?
Thanks.
Yes, I have tried that too. No luck.
Can't think of anything else. May be bringing up the other interface after same amount of time that NAT expires in would help.
Rais.
