PPP Multilink
ochalmers
Is it possible to configure a ppp multilink using a NM-CEM-4TE1 card on cisco router 2821?
I have tried and can't find the command.
Any help would be appreciated
John Blakley
I'm not sure about the actual card number, but to create a multilink the commands are:
int s0/0
encaps ppp
no ip address
ppp multilink
ppp multilink group 1
int s0/1
encaps ppp
no ip address
ppp multilink
int multilink1
ip address x.x.x.x 255.255.255.x
ppp multilink
That should be all you need to get them bonded.
HTH,
John
HTH, John *** Please rate all useful posts ***
