PPPOE problem
d.chevalier
I<m replacing a D-Link with a 1711 but pppoe synch is not happening. I know I have the right user/password. It's connecting to a micro-wave dish and it seems that sometimes there are delays.
If I reconnect the D-link, it comes back up .....
Ideas?
Daniel
Hello Daniel,
can you post the configuration of your 1711 router ?
GP
It is pretty standard ... it's working fine with 120 other routers ..... Here's the interface part of it
interface Null0
no ip unreachables
interface FastEthernet0
description $ETH-WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no snmp trap link-status
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
description $FW_INSIDE$$ETH-SW-LAUNCH$
ip address 10.102.253.30 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1300
interface Async1
description $BACKUP_INTF_FastEthernet0_TRACK_1$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer in-band
dialer pool-member 2
async mode dedicated
interface Dialer0
description $FW_OUTSIDE$
bandwidth 1500
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
ip inspect DEFAULT100 out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxx password xxxxx
service-policy output qos
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 2
dialer string 4186472447
dialer-group 2
no cdp enable
router eigrp 10
network 10.102.253.0 0.0.0.255
network 10.250.10.0 0.0.0.255
network 10.250.11.0 0.0.0.255
network 10.251.10.0 0.0.0.255
network 10.251.11.0 0.0.0.255
distribute-list 10 out
no auto-summary
ip local policy route-map SDM_BACKUP_RMAP_1
ip local pool clientpool 10.1.1.1 10.1.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 2
ip route 216.226.56.16 255.255.255.255 Dialer0
ip http server
ip http access-class 2
ip http authentication local
no ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip nat inside source route-map SDM_RMAP_2 interface Dialer1 overload
Do you need more?
Daniel
