PRI Problem
ashookoul
HI
I have 7507 router having MC E1 PRI 8 port card and on this card i have configured 3 pri lines ,i am having 3 additional pri lines to configure on this card when i configure 4 one no problem but when i configure 5 pri line i am getting error message:
% insufficient resources to create Pri-group - it has been removed
can anybody help me out what can be the problem.
AK
Georg Pauwen
AFAIK, the maximum available timeslots on the card is 128. Can you check if the total exceeds that number when you configure your fifth PRI ?
Check this document as well:
Configuring the PA-MC-2E1 and PA-MC-8E1
http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_rout/cfig_nts/5083e1p/5083conf.htm#xtocid272278
GP
Hello
Dear
Thanks for this for ur reply .
i have installed one more card and the problem gets solved.
AK
