Problem to ping LAN interface of a Router 1841(Noob Problem)
I´m tryin to ping my LAN interface 192.168.55.1 from host 192.168.0.211 that is at WAN interface 192.168.0.56 .
I already input at the host 211 the route add 192.168.55.0 MASK 255.255.255.0 192.168.0.56
But I´m getting nothing.
Here´s my running :
Current configuration : 1769 bytes
version 12.4
service password-encryption
hostname LafeRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$SYOW$1d/154C9R0oAxuf0s4CeO/
enable password 7 1411145C545D3A383C
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.55.1 192.168.55.10
ip dhcp pool LAN
   network 192.168.55.0 255.255.255.0
   dns-server 192.168.0.254
   default-router 192.168.55.1
ip dhcp pool lan
ip name-server 192.168.0.254
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 192.168.0.59 255.255.255.0
 ip access-group 100 in
 ip access-group 100 out
 ip nat outside
 ip virtual-reassembly
 speed auto
 full-duplex
 no mop enabled
interface FastEthernet0/1
 ip address 192.168.55.1 255.255.255.0
 ip access-group 101 in
 ip nat inside
 duplex auto
 speed auto
ip default-gateway 192.168.0.254
ip default-network 10.0.0.0
ip route 0.0.0.0 0.0.0.0 192.168.0.254
ip route 192.168.0.0 255.255.255.0 192.168.0.254
ip http server
ip nat inside source list 100 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.55.1 23 interface FastEthernet0/0 23
access-list 100 permit ip any any
access-list 101 permit ip any any
access-list 199 permit tcp 192.168.0.0 0.0.0.255 any
snmp-server community public RO
control-plane
line con 0
 exec-timeout 0 0
line aux 0
 exec-timeout 0 0
line vty 0
 access-class 199 in
 exec-timeout 0 0
 login
line vty 1 4
 access-class 199 in
 login
scheduler allocate 20000 1000
end
Thanks in advance
William Benson
I assume there is another router in the mix here.
Clients on the 192.168.0.0/24 have another router they're going through.
Does that router include the route to get to the 192.168.55.0/24 network?
It looks like the address is 192.168.0.254
So on 192.168.0.254 you need to update the routing table to include:
ip route 192.168.55.0 255.255.255.0 192.168.0.59
That lets the hosts on the 192.168.0.0/24 network to know that the 192.168.55.0/24 network is reachable through 192.168.0.59
Just my best shot in the dark at this point.
I'm confused why you would put ACLs on the interfaces on the router at 192.168.0.59 for both in and out on the inside and outside interface and have them set to permit ip any any
Why not just not have any ACLs at all since you're allowing all traffic anyways.
Thanks Wiliam Benson for the reply.
About the another router at 0.0/24 i was using "route add" directly at the host 0.211 to reach the 55.0/24 from which use 0.56 as gateway
I attached a screen of the scenario.
I know that i could setup a router at 0.0/24 and the configure the routes, but I want the host to reach it.
Thanks in advance.
