Problem with BGP
TekashiSixNine
Frequent Visitor
Frequent Visitor
config the router-reflector-client under the VPNv4.
please mention that this issue is solved.
Jon Marshall
Describe the problem and post the configurations here (you can replace public IPs with private ones if you want).
Jon
If i am right the issue is in vrf target import/export
Translator
Administrator
Administrator
Hello. I agree?
What are the defects? What you need to check is that it will be the next jump in PE in hr sessions.
