01-31-2011 09:35 AM - edited 03-04-2019 11:15 AM
Hi guys,
I am writing because I have a big problem with gns3.
1) I downloaded and decompressed the ios image file named “c1700-advipservicesk9-mz.124-15.T11” with winrar. I did not use cisco image upacker ( is this wrong?)
2) I chose the project directory and the image directory for gns3. To make it more simple I used the same folder for gns3 projects and images.
3) I configured dynamips. I Enabled the options “ghost ios feature’’, ’’mmap support’’ and I checked that dynamips was working perfectly.
4) Then from gns3 I chose the decompressed image named “C1700-AD ‘’
FIRST TROUBLE
I saw a message stating that “The path you have selected should contain only ascii (English) characters.
Dynamips does not support Unicode on Windows”
In spite of this message the image ios was loaded.
5) I left the base config option as “baseconfig.txt” (should I change it?)
6) I chose the platform and the model (I am sure about the platform but I am not sure about the exact model…On step 7 I checked all the models but no one was working. Of course the image file is not false I have checked it)
7) I saved the image and then dragged the router image of the platform in order to design my network.Everything worked perfect till then.
SECOND TROUBLE
I saw a message stating “209-UNABLE TO START VM INSTANCE-R1’’
Of course my router cannot boot up and I don’t know what I do wrong.Of course I tried it many times with lots of images but every time happened the same thing.
I would appreciate if someone of you helped guys! Thank you in advance! I am waiting for suggestions because I need gns3 in order to practice for ccnp routing!
01-31-2011 10:13 AM
Wether you leave IOS as is(.bin) or you can decompress with winrar but you must give it the extension .image and rename it with the name of the original .bin file.
That's why your router won't start as he finds no valid IOS.
Regards.
Alain.
01-31-2011 10:37 AM
very intersting Alain! Could you tell me how i change the bin file to image?the unpacked file is for example C1700-AD. it does not have an extension on its name....how can i transform it to an image file? sorry but i am not an expert on these things my friend....i would appreciate if you could give me an wxample......anyway thank you very much!!!!!!!!!
A new message was posted in the Discussion thread "problem with gns3":
https://supportforums.cisco.com/message/3282272#3282272
Author : cadetalain
Profile : https://supportforums.cisco.com/people/cadetalain
Message:Date: Mon, 31 Jan 2011 11:14:09 -0700
Subject: New message: "problem with gns3"
jim karan,
01-31-2011 10:41 AM
when decompressed with winrar then you rename to c1700-advipservicesk9-mz.124-15.T11.image
and you use this as the IOS image.
Regards.
Alain.
01-31-2011 10:48 AM
dear Alain i did it but i still have the same problem?any other suggestions my friend?
Date: Mon, 31 Jan 2011 11:41:56 -0700
jim karan,
https://supportforums.cisco.com/message/3282277#3282277
Author : cadetalain
Message:
01-31-2011 10:52 AM
Can you post baseconfig.txt
Regards.
01-31-2011 10:56 AM
this is it.hope it helps
Date: Mon, 31 Jan 2011 11:52:43 -0700
jim karan,
https://supportforums.cisco.com/message/3282280#3282280
Author : cadetalain
Message:
01-31-2011 11:40 AM
Ok,
It was no help indeed.
On which OS are you?
Is Dynamips process started? it should listen on TCP 7200 on localhost.
Is the path to IOS image ok?
Can you find the .net file made by GNS3?
Regards.
01-31-2011 12:03 PM
windows 7
dynamips working fine as i tested gns3
base port 7200.... ( is it ok?)
where can i find it?
thank you again.......i don t know what to do!
i want to state something......previously you told me how to convert a bin file to image.....although i changed it as you told me #######.image the file was recognized aome s a bin file.....is this of any importance?
os:
jim karan,
Send
https://supportforums.cisco.com/message/3282288#3282288
Author : cadetalain
Message:Date: Mon, 31 Jan 2011 12:40:45 -0700
01-31-2011 12:15 PM
The only difference is that the .image file is already uncompressed so you gain time when loading IOS in ram.
On windows 7 you must start dynamips as administrator did you do it?
For the .net file just do a search for this file because I don't know where it resides.
Regards.
Alain.
01-31-2011 02:26 PM
no what should i do in order to start dynamips as administrator?
thank you one more time!
Date: Mon, 31 Jan 2011 13:15:55 -0700
jim karan,
https://supportforums.cisco.com/message/3282358#3282358
Author : cadetalain
Message:
01-31-2011 11:26 PM
To start a program as administrator you right click and then run as administrator.
You must do this for GNS3 which is using Dynamips.
Regards.
Alain.
01-31-2011 11:42 PM
No it did not work at all! any other suggestions?
Date: Tue, 1 Feb 2011 00:26:23 -0700
jim karan,
https://supportforums.cisco.com/message/3282696#3282696
Author : cadetalain
Message:
02-01-2011 12:01 AM
Can you post screenshots of what you did in GNS3 and of the directory where your IOS is with its name.
Regards.
Alain.
02-01-2011 12:20 AM
i am sending them...if you need anything else you can tell me
Date: Tue, 1 Feb 2011 01:01:38 -0700
jim karan,
https://supportforums.cisco.com/message/3282701#3282701
Author : cadetalain
Message:
