Process switching for WIC-1ADSL
everywherenick
I recently setup a solution to load balence traffic from a LAN over 2 ISP ADSL connections.
The setup works perfectly for one major draw back. For some reason all the packets arriving on the fastethernet interface are being process switched :(
This is causing the task IP INPUT to eat all availble CPU when the router gets busy.
Here is the config i am running.
version 12.3
hostname syd01-c36
boot-start-marker
boot-end-marker
logging buffered 50000 debugging
no logging console
no logging monitor
enable password nottellingyou
aaa new-model
aaa session-id common
ip subnet-zero
ip cef
ip name-server 10.1.0.1
ip dhcp pool eisyd01
network 10.1.2.0 255.255.255.0
dns-server 10.1.2.1
default-router 10.1.2.1
domain-name syd01
ip audit po max-events 100
interface ATM0/0
bandwidth 1500000
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0/0
ip address 10.1.0.4 255.255.254.0
ip nat inside
duplex auto
speed auto
standby ip 10.1.0.5
standby priority 110
standby preempt
interface ATM0/1
bandwidth 1500000
no ip address
pvc 8/35
dialer pool-member 2
interface FastEthernet0/1
ip address 10.1.2.1 255.255.255.0
ip nat inside
rate-limit input 512000 3500 3500 conform-action transmit exceed-action drop
rate-limit output 512000 1500 2000 conform-action transmit exceed-action drop
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
bandwidth 1500000
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username someuser@someisp.com.au password somepassword
interface Dialer2
bandwidth 1500000
ip nat outside
encapsulation ppp
dialer pool 2
no cdp enable
ppp chap refuse
ppp pap sent-username someotheruser@someisp.com.au password somepassword
ip nat inside source route-map rmsyd01 interface Dialer1 overload
ip nat inside source route-map rmsyd02 interface Dialer2 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip dns server
access-list 1 permit any
access-list 2 permit any
access-list 100 permit ip any any
route-map rmsyd02 permit 10
match ip address 1
match interface Dialer2
route-map rmsyd01 permit 10
match ip address 1
match interface Dialer1
and here is the problem:
syd01-c36#show interfaces f0/0 switching
FastEthernet0/0
Throttle count 0
Drops RP 10 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 6914 Drops 0
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 376101 66911974 31196 4458462
Cache misses 2 - - -
Fast 7 1037 399068 376452603
Auton/SSE 0 0 0 0
Those 7 packets were while the DSL was coming up :(
Show ip interface on all those concerned shows fast switching and CEF switching enabled.
A debug ip packet detail shows the packets using the RIB. What i can't figure out is why....
Any and all help gratefully received!
everywherenick
Not even a RTFM? or a "its the nats Fault"? What ver IOS (12.3.13a) or anything? :)
Please help.
