08-04-2010 07:00 AM - edited 03-04-2019 09:18 AM
Hi All,
I know is not advisable, but I need to see the options available for this scenario.
I have about 30 remote sites (some connected via Internet IPsec tunnels and some via Wireless links).
I need to propagate a VLAN through the WAN sites for Avaya IP phones.
I've seen that L2TPv3 is an option for propagating a VLAN across a WAN (not depending on the SP) but it supports Frame Relay, Ethernet, 802.1q, HDLC, PPP (so does it support an underlying Wireless link?)
Is there any other option considering I don't want to depend on the SP and we're not using MPLS?
Thank you for any help.
Federico.
08-04-2010 08:24 AM
You could use QinQ or you could use something like an Adtran and break out your WAN connection to serial and L2 bridging.
08-04-2010 08:46 AM
Collin,
Can I configure QinQ on both sides of the WAN (on my routers) and that's it? Or do I need the SP involved?
Federico.
08-04-2010 08:54 AM
No SP involvement is necessary. Check the feature navigator as it is not supported on all devices.
08-04-2010 11:40 AM
coto.fusionet wrote:
Hi All,
Federico.
Federico
If your devices support it then L2TPv3 is the way to go ie. most routers do support it most switches don't.
When you ask about it supporting underlying wireless link that doesn't matter because L2TPv3 doesn't care about the actual media as such but rather about the L2 protocol running acorss the media so assuming your wireless is running ethernet you should be fine.
I'm not sure Q-in-Q will actually help across a routed network although i may be wrong. My understanding is Q-in-Q works when the sites are connected via a L2 vlan already and you want to send your own vlans across that.
Jon
08-04-2010 12:04 PM
John,
Thank you I will look into L2TPv3
Collin,
I did not gave you a 2 in score. Honestly I don't know what happened. Has this happened before?
Federico.
