PVST VLAN loadbalance- Switching
niranjan5
I need vlan loadbalacing in PVST Mode how to do it is there any help ?
my senario is
2 core switch , one link from 1 core and 2 link from another core connected to one 4510R distribution switch and from distribution to 2 uplink connected to one access switch.
all vlan interfaces are in 6509 core switch...
so how to loadbalance network for vlan
Giuseppe Larosa
Hello Niranjan,
you can achieve load-sharing on per vlan basis.
there are two tools you can use, one or both, to achieve this.
First of all you can make core1 root bridge for a subset of existing vlans and core2 root bridge for the remaining vlans.
This should provide STP forwarding state for first set of vlans on direct link to core1 and STP forwarding state for the second set of vlans on link towards core2
spanning-tree root primary macro accepts a range of vlans expressed as XX,YY,Z1-ZN, you need to use ',' as separator without spaces in the middle.
another tool that can help is
on the link interface configuration
spanning-tree pervlancost Vlan-range were you can increate the STP cost on the access switch uplinks for the vlans you want to be in STP forwarding state on the other uplink. You then do the opposite on the other uplink
Hope to help
Giuseppe
