Python config help
PLC
Level 3
Level 3
Hello everyone,
Need some help with python script. I never used python before. I need to deploy tacacs config for con0 and aux line to all routers and switches.
I have Python 2.7.13 installed on my windows 7
1. I have a router I want to test it by deploying script to it via telnet. How do you suggest i do that while having this router connected to a production network? My thought is to not have any routing enabled and only configure a loop back on the router with an IP address that is routable via the production network. Best practices?
2. I have attached what i have so far scripted very rough draft. I have no idea how to deploy it with python via telnet and what the script is lacking. would i put the IP address of the router where it says "(HOST)". Can anyone give me some pointers?
Thank you!
33 Replies 33
Hi Francesco,
It's going to take me a bit to get a router test on since I had to deploy the one I had.
I attached a very basic one. I wanted to make sure I get the basic concepts because i will have to explain in a project plan what the script is doing and test it. Plus it was easier to find what was wrong when it didnt work.
so originally the scripts never worked because I found that I had a no aaa new model and did not have that enabled so the commands didnt work at all when running the script. Once I identified that I enabled and ran my script which worked up to the point of configuring the aaa global config mode BUT it didnt work all the way. I saw that the login configuration under line con 0 and aux 0 had no configuration.
Thanks for you help.
P
Ok you script seems good.
Let me know when you'll have your router to test if you face some issues.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
So with my simple script that I sent you I did run into an issue.
it configures global config mode the aaa but when going into line con0 and line aux it does not configure. I will have a router to test next week. but any ideas why?
Hey
By looking at it in details, behind your line command you did /n instead of \n
Correct that and try again.
Francesco
