QoS Compatible IoS
netbeginner
Level 2
Level 2
Hello All,
We have cisco 3750 series switch with IOS version 12.2(35)SE5. which is not accepting Q0S and PBR . Please suggest for the version which can be compatible for PBR/QoS.
Jon Marshall
netbeginner wrote:
Hello All,
Can you be more specific about "not accepting QOS" ie. which commands are not being accepted.
As for PBR you will need Advanced  feature set - which feature set are you running ? If you aren't sure post the output of a "sh version"
Jon
