QoS for routing
FernandoSP
I would need to implement QoS in a ADSL line with Dial-UP connection.
I've read that maybe with a router 877, i could have some problems for applying QoS in this dial-up line.
Have you ever tried to make it? If it wasn't possible to implement this option in 877, which alternative dou you suggest me?
Thanks.
you can apply QoS in the ATM subinterface without problems.
Config example:
class-map match-all MuMe
match access-group name Multimedia
class-map match-all BRONZE
match access-group name Trafico_BRONZE
class-map match-all SUC
match any
class-map match-all SILVER
match access-group name Trafico_SILVER
class-map match-all GOLD
match access-group name Trafico_GOLD
policy-map QOS
class MuMe
priority 2560
class GOLD
bandwidth 8
class SILVER
bandwidth 8
class BRONZE
bandwidth 17920
policy-map SUC
class SUC
shape average 100000000
service-policy QOS
policy-map MARK
class MuMe
class GOLD
class BRONZE
class SILVER
interface ATM0.1 point-to-point
description ADSL data PVC
mtu 1500
ip address 10.10.10.1 255.255.255.252
bandwith 1024
pvc 8/35
vbr-rt 1250 1250
tx-ring-limit 3
no oam-pvc manage
service-policy output SUC
service-policy input MARK
Raul
(please rate helpful posts)
rkhalil
Fernando:
Where you need apply QoS on the ADSL line ( ATM interface ?? ) or you have a pstn modem attached in the aux port ?
Raul
Hi Raul,
In the ATM interface.
Fernando.
Config example:
match any
policy-map QOS
class MuMe
priority 2560
class GOLD
bandwidth 8
class SILVER
bandwidth 8
class BRONZE
bandwidth 17920
policy-map SUC
class SUC
service-policy QOS
policy-map MARK
class MuMe
class GOLD
class BRONZE
class SILVER
mtu 1500
bandwith 1024
pvc 8/35
vbr-rt 1250 1250
tx-ring-limit 3
no oam-pvc manage
Raul
OK,
Thanks.
Fernando.
