QOS issue on 6500
mohammedrafiq
Hi All,
I am trying to convert QOS policy on 6500 CAT to IOS as below,
1-getting error when try to apply on  interface.
2-How can I apply both into one plicy map because IOS convertor puts into two policy maps.
Please can any one check and advise any alternative.
CAT
set qos policer aggregate Limit_WSUS rate 4000 policed-dscp erate 4000 drop burst 1000 eburst 1000
set qos policer aggregate Limit_SCCM rate 4000 policed-dscp erate 4000 drop burst 1000 eburst 1000
clear qos acl all
#WSUS
set qos acl ip WSUS dscp 0 aggregate Limit_WSUS ip host 172.16.9.3 any
set qos acl ip WSUS dscp 0 aggregate Limit_SCCM ip host 172.16.10.5 any
commit qos acl all
set qos acl map WSUS 750
IOS
interface Vlan750
description ******BT-PRIMARY-LINK*****
ip address 1.1.1.1 255.255.255.252
ip ospf network point-to-point
ip ospf cost 5
shutdown
ipx network 180755
mls qos
mls qos aggregate-policer Limit_WSUS 4000000 1000000
mls qos aggregate-policer Limit_SCCM 4000000 1000000
ip access-list extended WSUS-1
permit ip host 172.16.9.3 any
class-map WSUS-1-class
match access-group name WSUS-1
policy-map WSUS-policy
class WSUS-1-class
  set dscp 0
  police aggregate Limit_WSUS
ip access-list extended WSUS-2
permit ip host 172.16.10.5 any
class-map WSUS-2-class
match access-group name WSUS-2
class WSUS-2-class
  set dscp 0
  police aggregate Limit_SCCM
interface vlan750
service-policy input WSUS-policy
RT1(config)#interface vlan750
RT1(config-if)# service-policy input WSUS-policy
QoS-ERROR: Addition made to policymap WSUS-policy and class WSUS-1-class is not valid, command is rejected
RT1(config-if)#
Feb 22 10:31:49.439: %QM-6-SET_AND_POLICE: 'set' and 'police' commands cannot co-exist in classmap WSUS-1-class of policymap WSUS-policy
0 Replies 0
