QoS on 1841 router with ADSL interface
msafargaleev
I'm trying to set up QoS on ADSL interface.
Below is part of configuration:
class-map match-all voip
match access-group name qos
policy-map marking
class voip
priority 120
set ip dscp ef
policy-map test
class class-default
shape average 1000000
service-policy marking
interface ATM0/0/0.1 point-to-point
description WAN
ip address 10.1.163.129 255.255.255.252
pvc 0/34
encapsulation aal5snap
service-policy output test
However, i see nothing in show policy-map interface ATM0/0/0.1 command.
IOS version 12.4-6.T5 advanced security. Why this happen? Thanks in advance.
8 Replies 8
mheusinger
Level 10
Level 10
Are there any other interfaces involved, like Dialer or virtual template? Can you post the complete router config?
Regards, Martin
lgijssel
Level 9
Level 9
First step will be to determine whether you are receiving packets that match the policy map. What does your access-list qos look like? Can you see that it matches packets?
Use "sh access-list" to verify this.
Please find some config tipsin the link below:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b04.html
Leo
Thanks for replay.
This is complete configuration:
Current configuration : 6491 bytes
version 12.4
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot system flash c1841-advsecurityk9-mz.124-6.T5.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
no aaa new-model
resource policy
no ip source-route
ip cef
no ip domain lookup
ip ssh time-out 60
ip ssh authentication-retries 2
policy-map marking
class voip
priority 120
set ip dscp ef
policy-map test
class class-default
interface FastEthernet0/0
description LAN
ip address 192.168.162.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
ip address 10.1.163.193 255.255.255.252
no snmp trap link-status
pvc 8/35
ip route 0.0.0.0 0.0.0.0 ATM0/0/0.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended qos
permit ip host 192.168.162.6 host 192.169.163.163
control-plane
line con 0
logging synchronous
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
Leo, i don't think that this is related to access-list because when i put service-policy test oh fastethernet 0/0 interface (this interface not used in my scenario and in "down" state) i see command output
sho policy-map interface fastEthernet 0/1
FastEthernet0/1
Service-policy output: test
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
1000000/1000000 6250 25000 25000 25 3125
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 0 0 0 0 no
Service-policy : marking
Class-map: voip (match-all)
0 packets, 0 bytes
Match: access-group name qos
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 120 (kbps) Burst 3000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 0
0 packets, 0 bytes
Match: any
My suggestion is that you try it like the example in:
http://www.cisco.com/en/US/tech/tk39/tk824/technologies_configuration_example09186a0080094cf6.shtml#sampleconfig
According to that example, your policy-map test should look like this:
policy-map test
class voip
priority 120
set ip dscp ef
class class-default
Leo
I just copy and pasted your config into 7200 with 12.4(9)T and it works.
Difference:
interface ATM1/0
no ip address
interface ATM1/0.1 point-to-point
pvc 8/35
So I had no "dsl operating-mode auto" and the service-policy is configured in subif and not PVC mode.
Might be your IOS as well.
Hope this helps! Please use the rating system.
Regards, Martin
Martin,
When i trying to attach service-policy in subinterface mode i have this error:
router(config-subif)#service-policy output test
GTS : Not supported on this interface
although, as i've read here http://www.cisco.com/warp/public/121/where_policy.html
it should be supported configuration
Hm. Another idea:
Can you try something like
int atm1/0.1
pvc 8/35
class-vc Myclass
vc-class Myclass
service-policy output Test
Unfortunately I cannot test this here. Just reminds me on the frame-relay approach, where the policy-map can only be applied to a "map-class frame-relay" and not directly to a FR sub-interface.
Regards, Martin
It isn't possible to attach service-policy into class-vc atm (at least on my router).
I'll try to use latest version of Cisco IOS, perhaps it's help.
