QOS on port-channel subinterface ASR 1002-X
vincent.egal
I'm trying to configure some shaping and policing on a port-channel subinterface on my ASR1002-X IOS XE 03.09.02.S without success .
Is the feature supported on my version or does it need an other?
thanks
class-map match-any CLASS_WIFI_DC_IN
 match any
class-map match-any CLASS_WIFI_DC_OUT
 match any
policy-map POLICY_WIFI_DC_OUT
 class CLASS_WIFI_DC_OUT
  shape average 10000000
policy-map POLICY_WIFI_DC_IN
 class CLASS_WIFI_DC_IN
  police cir 10000000
   exceed-action drop
   violate-action drop
interface Port-channel1.3013
 description CTRL-WIFI
 encapsulation dot1Q 3013
 ip address 95.81.167.69 255.255.255.248
 service-policy input POLICY_WIFI_DC_IN
 service-policy output POLICY_WIFI_DC_OUT
TOM#show policy-map interface
 Port-channel1.3013
  Service-policy input: POLICY_WIFI_DC_IN
    Service policy POLICY_WIFI_DC_IN is in suspended mode
  Service-policy output: POLICY_WIFI_DC_OUT
    Service policy POLICY_WIFI_DC_OUT is in suspended mode
5 Replies 5
Deniz AYDIN
Traditional QoS will not work for etherchannels. Please read to find suitable config for your case.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-mqc-xe-3s-book/qos-eth-int.html#GUID-6137A7B8-B2D1-4024-8AC9-E7EBEDD868C6
hi,
it's possible to achieve service-policy work applied to port-channel subinterface, however it's more like workaround than fix or solution. you can use:
1. global configuration command - port-channel load-balancing vlan-manual, but it will disable load balancing from flow-based algorithm and move all traffic to only member of port-channel interface.
2. port-channel subinterface command - encapsulation dot1q 2 primary gigabitethernet2/1/0 secondary gigabitethernet8/0/0 (encapsulation dot1Q vlan-id primary member-link secondary member-link)
also here is the link - http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/lanswitch/configuration/xe-16/lanswitch-xe-16-book/lnsw-vlan-map-gig.html
and I would be glad to know if there is available more elegant solution for this issue with flow-based load balancing.
Hi Ruslan,
Another Solution for the Suspended QOS with Port-Channel with Sub-interfaces without using the "load-balancing vlan".
you can use the Aggregate GEC QOS (which will provide Flow based Etherchannel QOS), Below is a sample Configurations:
platform qos port-channel-aggregate 1  ==> issue this command before creating Port-Channel 1
Then create the Port-channel "1" & apply the QOS under Port-channel Sub-interface..
The "Aggregate GEC QOS" Feature is supported from in XE 3.16.3 & later..
Hope this could help,
Islam
hi Islam,
thanks for your answer.
unfortunately I don't have opportunity to test this solution now, but anyway thanks, I beleive this will do the trick.
Yeah, that's it.
Thank you very much for your help
Gianni
