question about cisco access server and securecrt
BGP65111
Good day all,
I don’t know how to setup my securecrt to let me start multiple TAPS  Sessions through my serial cable (I have no Ethernet connection to my  access server just octal cable which is useing COM3)
Is it possible to open multiple console sessions ?
If yes please let me know how.
Thanks a lot
Reza Sharifi
Yes you can open multiple taps using secure CRT if you have one of the newer
See this link
http://www.vandyke.com/support/tips/dragouttabs.html
Dear Rezam
i have new one and it's working fine but i need to open multiple TAP sessions on my securecrt to mange all my 7 routers on the same time.
is this aplicable?
Yes it is if for example you have 10 routers you can open up a session for each
That would creat 10 taps
even i have only console conecctions ?
Because I try to open multi console connections TAP sessions to my routers but I couldn’t
I can only open one session to my access server.
