Radius connection Problem (Routing wrong?)
Markus Thun
Level 3
Level 3
Hello Community,
VPN over IPSec (Site-2-Site)
Here is the Configuration of the Cisco 1841 Router:
//Login Credentails
enable secret xxxxxx
username admin privilege 15 password xxxxxx
//ACL for VPN and NAT
access-list 102 permit ip 192.168.192.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 102 permit ip 192.168.192.0 0.0.0.255 172.20.0.0 0.0.0.255
access-list 150 deny   ip 192.168.192.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 150 deny   ip 192.168.192.0 0.0.0.255 172.20.0.0 0.0.0.255
access-list 150 permit ip 192.168.192.0 0.0.0.255 any
//ACL
ip access-list extended inboundfilter
evaluate reflectacl
permit udp any host <<WANIP>> eq isakmp
permit tcp any host <<WANIP>> eq 22
permit icmp any host <<WANIP>>
ip access-list extended outboundfilter
permit ip any 192.168.0.0 0.0.255.255 reflect reflectacl
permit ip any 172.20.0.0 0.0.0.255 reflect reflectacl
deny   udp 192.168.XXX.0 0.0.0.255 any
permit ip any any reflect reflectacl
//VPN settings
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key xxxxxxxxx address xxxx.xxx.xxx.226
crypto isakmp keepalive 30
crypto ipsec transform-set SET esp-aes esp-sha-hmac
crypto map B2B 10 ipsec-isakmp
description b2b-fw-ushou-1
set peer xxx.xxx.xxx.xxx
set security-association lifetime seconds 86400
set transform-set SET
match address 102
//Interface configuration
interface FastEthernet0/0
description wan_primary
ip access-group inboundfilter in
ip access-group outboundfilter out
crypto map B2B
interface FastEthernet0/1
ip nat inside
route-map nonat permit 10
match ip address 150
ip nat inside source route-map nonat interface FastEthernet0/0 overload
The cisco 1841 router will you for ssh the aaa authentication method. But the router can not ping over the VPN in the remote LAN. The router can not reach the Radius server. Have anybody an idea to solve this issue?
Best Regards
Markus Thun
11 Replies 11
Richard Burts
There are some details that you have not included in your post that would have been helpful, such as the IP address of the interfaces, and whether you have specified a source address in attempts to access the Radius server. But based on the symptoms you describe I will make a guess that the router is using the IP address of its public interface as the source address for these attempts and that this address is not included in your crypto access list and so is not encrypted. If you specify a source address of the inside interface does it work better?
Rick
Rick
Hi, here are some other informations:
aaa group server radius LOGIN
server 192.168.5.24 auth-port 1812 acct-port 1813
ip radius source-interface FastEthernet0/1
aaa authentication login LOGIN group radius local
ip address 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map B2B
description besidjakr1_lan
ip address 192.168.192.1 255.255.255.0
ip nat inside
duplex auto
speed auto
If i use the command: ping 192.168.5.24 source fastethernet 0/1 , i an ping the radius but if i use only ping 192.168.5.24 i cannot reach this server.
Best regards
Markus
Markus
That is exactly the issue that I described. If you just ping 192.168.5.24 the router by default will choose the outbound interface as the source address and the ping will not go through the VPN tunnel. If the ping does not go through the VPN tunnel then 192.168.5 is not routable through the Internet. So the ping will work only if you choose a source address that will match the crypto access list and will go through the tunnel.
The good thing is that the additional information included in this post does show that you have specified the source address for Radius. So the Radius request should match the crypto access list and should go through the VPN tunnel. I am guessing that the reason that Radius is not working may be related to the fact that you gave the Radius server group a name but do not use that name in the aaa commands. I suggest that either you change
to
or change this
to
aaa authentication login LOGIN group LOGIN local
or maybe to
aaa authentication login default group LOGIN local
Rick
Rick
my changes:
access-list 102 permit ip 192.168.192.0 0.0.0.255 host 192.168.5.24
access-list 150 deny   ip 192.168.192.0 0.0.0.255 host 192.168.5.24
Still the same Problem.
Markus
Please post the configuration for line con 0 and for all of your vty lines.
Rick
Rick
The configuration for the lines are correct.
here the output (debug radius):
*Nov 14 15:43:48.780 CET: RADIUS/ENCODE(0000000B): ask "Password: "
*Nov 14 15:43:48.780 CET: RADIUS/ENCODE(0000000B): send packet; GET_PASSWORD
fw-idjkt-1#
*Nov 14 15:43:55.055 CET: RADIUS/ENCODE(0000000B):Orig. component type = EXEC
*Nov 14 15:43:55.055 CET: RADIUS:  AAA Unsupported Attr: interface         [157]                                                      6
*Nov 14 15:43:55.059 CET: RADIUS:   74 74 79 31        [tty1]
*Nov 14 15:43:55.059 CET: RADIUS/ENCODE(0000000B): dropping service type, "radiu                                                     s-server attribute 6 on-for-login-auth" is off
*Nov 14 15:43:55.059 CET: RADIUS(0000000B): Config NAS IP: 192.168.192.1
*Nov 14 15:43:55.059 CET: RADIUS/ENCODE(0000000B): acct_session_id: 11
*Nov 14 15:43:55.059 CET: RADIUS(0000000B): sending
*Nov 14 15:43:55.059 CET: RADIUS: Long password processing
*Nov 14 15:43:55.059 CET: RADIUS(0000000B): Send Access-Request to 192.168.5.24:                                                     1812 id 1645/10, len 106
*Nov 14 15:43:55.059 CET: RADIUS:  authenticator 0C E4 4D 0E B4 E1 13 AB - 96 9D                                                      04 9B EE AF B0 24
*Nov 14 15:43:55.059 CET: RADIUS:  User-Name           [1]   13  "markus.XXXX"
*Nov 14 15:43:55.059 CET: RADIUS:  User-Password       [2]   34  *
*Nov 14 15:43:55.059 CET: RADIUS:  NAS-Port            [5]   6   196
*Nov 14 15:43:55.059 CET: RADIUS:  NAS-Port-Id         [87]  8   "tty196"
*Nov 14 15:43:55.059 CET: RADIUS:  NAS-Port-Type       [61]  6   Virtual        [5]
*Nov 14 15:43:55.059 CET: RADIUS:  Calling-Station-Id  [31]  13
fw-idjkt-1#"192.168.5.5"
*Nov 14 15:43:55.059 CET: RADIUS:  NAS-IP-Address      [4]   6   192.168.192.1
fw-idjkt-1#
*Nov 14 15:43:59.991 CET: RADIUS: no sg in radius-timers: ctx 0x636E3D9                                                              00
*Nov 14 15:43:59.991 CET: RADIUS: Retransmit to (192.168.5.24:1812,1813                                                              1645/10
fw-idjkt-1#
*Nov 14 15:44:04.630 CET: RADIUS: no sg in radius-timers: ctx 0x636E3D9                                                              00
*Nov 14 15:44:04.630 CET: RADIUS: Retransmit to (192.168.5.24:1812,1813                                                              1645/10
fw-idjkt-1#
*Nov 14 15:44:09.430 CET: RADIUS: no sg in radius-timers: ctx 0x636E3D9                                                              00
*Nov 14 15:44:09.430 CET: RADIUS: Retransmit to (192.168.5.24:1812,1813                                                              1645/10
fw-idjkt-1#
*Nov 14 15:44:13.973 CET: RADIUS: no sg in radius-timers: ctx 0x636E3D9                                                              00
*Nov 14 15:44:13.973 CET: RADIUS: No response from (192.168.5.24:1812,1                                                              id 1645/10
*Nov 14 15:44:13.973 CET: RADIUS/DECODE: No response from radius-server                                                              esponse; FAIL
*Nov 14 15:44:13.973 CET: RADIUS/DECODE: Case error(no response/ bad pa                                                              decode);parse response; FAIL
fw-idjkt-1#
*Nov 14 15:44:16.645 CET: RADIUS/ENCODE(0000000B): ask "Password: "
*Nov 14 15:44:16.645 CET: RADIUS/ENCODE(0000000B): send packet; GET_PAS
Markus
The debug shows that your router is sending a request with the source address that you requested and it should match the crypto access list. So I assume that it was sent through the tunnel. If the Radius server is not responding then there appears to be some issue. My first suggestion would be to check the shared secret used to communicate between router and server. If that appears to be correct then I would suggest checking the logs from the server. Did the server see the request? Do the logs show why the server did not send a response? My experience in symptoms like this is that frequently the server does not recognize the request as coming from a valid (configured correctly) client.
Rick
Rick
the radius server get no packets from the 1841. ( There are no logs at the Radius Server)  The router send no packets (radius) of the vpn connection.
Markus
I am surprised at this. The debug in your previous post looked like it was generating requests to the Radius server. And it looks like the traffic should have matched your crypto access list. So I am not sure why traffic is not going over the VPN tunnel. Perhaps a fresh copy of the current config might help us figure out the issue?
Rick
Rick
Can i work with route maps?
Markus
I do not understand this question. What would you be using route map for?
Rick
Rick
