RAS help
bube
Hi All,
I have problem with the RAS server configured on Cisco 3745 as a callback server. The PRI interface is connected to Ericsson MD110 PBX. This PBX is connected to PSTN trough 2 E1 trunks. The system is working fine from some numbers from the public PSTN network, but from others numbers is not possible to establish full callback communications (only regular dial-up). Do i need to put some additional commands on the modems or........?. This is my configuration. Thanks in advanced.
router#sh run
Building configuration...
Current configuration : 3069 bytes
! Last configuration change at 08:10:52 CST Fri Apr 1 2005
! NVRAM config last updated at 15:18:10 CST Thu Mar 31 2005
version 12.2
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname router
logging count
logging buffered 500000 debugging
aaa new-model
aaa authentication login default local
aaa authentication login NO_AUTHEN none
aaa authentication ppp default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization exec NO_AUTHOR none
aaa authorization network default group tacacs+ local
aaa accounting network default start-stop group tacacs+
aaa session-id common
enable secret 5 xxxxxxxxxxxxxxx
username xxxxxxxx password 7 xxxxxxxx
clock timezone CST -6
clock summer-time CST recurring
ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name xxxxxxxxxxxx
ip name-server xxxxxxxxxxxx
no ip bootp server
isdn switch-type primary-net5
chat-script callback ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 30 CONNECT \c
chat-script offhook "" "ATH1" OK \c
controller E1 3/0
pri-group timeslots 1-31
controller E1 3/1
interface Loopback0
ip address 10.1.3.1 255.255.255.0
interface FastEthernet0/0
ip address 10.1.2.10 255.255.255.224
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial3/0:15
no ip address
encapsulation ppp
no ip route-cache
dialer-group 1
isdn incoming-voice modem
no peer default ip address
no cdp enable
interface Group-Async2
ip unnumbered Loopback0
encapsulation ppp
no ip route-cache
ip tcp header-compression passive
no ip mroute-cache
async mode interactive
peer ip address forced
ppp callback accept
ppp authentication chap
group-range 129 140
ip local pool IP_POOL 10.1.3.2 10.1.3.100
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.2.1
no ip http server
ip pim bidir-enable
no cdp run
tacacs-server host 10.1.1.5
tacacs-server key xxxxxxxxxxxx
line con 0
line 129 140
script modem-off-hook offhook
script callback callback
modem InOut
rotary 10
transport preferred none
transport input all
autoselect during-login
autoselect ppp
callback forced-wait 10
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 xxxxxxxxxxxxxxxxxx
end
router#
Not applicable
The configuration looks good to me. Since the callback function works for some numbers i guess there is nothing wrong with the configuration.Is call back not working for numbers from a particular service provider, in that case you will have to check with the service provider if something needs to be done at the service providers end.
Thanks a lot for your reply. I almost lost fate that somebody would answer to my post.
There is only one service provider in our country (telephone service provider). The PSTN switches that our provider is using are Alkatel and EWSD Siemens. We are not sure that the root of the problem is in some models of switches. We are in a researching phase to check if there is a conflict with a certain type of switches. Do you know of any specific setting for the modems or the chat script for any of these PSTN switches in correlation with the existing local PBX Ericsson MD110?
