Redistribute static Ospf
Randikdik
Community Member
Hi all,
i have topologi forti(as a router internet &mpls) - Core switch - Palo-Alto ( FW server Farm)
Connection core to forti using ip p2p & static default route 0.0.0.0/0 for access internet & access MPLS,
Connection core to Palo-Alto using ip p2p & configure OSPF
Do I need to apply configuration redistribute so that the segment on the Palo Alto, which uses OSPF, can communicate outward through the default route toward the FortiGate?
Giuseppe Larosa
Hello @Randikdik ,
on the Cisco core switch you can generate an OSPF default route in OSPF routing domain using:
router ospf 10
default-information originate
to be noted Cisco implementation does not allow to redistribute a default route from static to OSPF.
However, the command will provide a default route until there is a the default static route installed in the core switch
Hope to help
Giuseppe
Giuseppe Larosa
Hello @Randikdik ,
router ospf 10
Hope to help
Giuseppe
Randikdik
Community Member
hi @Giuseppe Larosa
thank you for your help. I’ve tried it and it worked.
