remote access ssh 2960
pcfreak49
I have a question you do do remote access ssh and telnet remotly to a 2960 switch?
6 Replies 6
  Do you want to manage C2960 via telnet and ssh? If yes, sure you can.
Toshi
I mean can you do that from another ISP?
Hi Guys,
    First off, we are willing to help you here. However, we need to know exactly what the problem/question is. Please clarify what you exactly want to do. We sometime need detailed information to get the same picture as yours.
Toshi
I want an ssh connection to a switch at home, at my school a ssh to the switches for that exam but do not know if this is possible
can you tell me something if this is possible please
Richard Burts
It depends on several things. Most important is whether the switch is reachable from the Internet. If the switch is dynamically natted as most devices in home installations are then it would not be reachable from the Internet and you would not be able to SSH to it.
Rick
Rick
the switches of the audience get an ISP that will allow gekent all ports of the switches?
it is possible to correct the wan port to provide a public ip address instead of all eight poortn
