10-30-2017 12:25 PM - edited 03-05-2019 09:24 AM
Dear All,
I am having doubt in BGP RIP failure.
in my BGP configuration i am not added redistribute static command but i am having static route.
In that time for that mentioned static routes i am getting RIB failure alert.
But if i added redistributed static in bgp the rip failure is not coming.
Can anyone explain what is happening while adding the redistributed static in BGP.
R1#sh running-config | section route
router bgp 10
no synchronization
bgp log-neighbor-changes
network 192.168.1.0
neighbor 10.0.0.2 remote-as 20
no auto-summary
ip route 192.168.2.0 255.255.255.0 10.0.0.2
R1#sh ip bgp neighbors 10.0.0.2 advertised-routes
BGP table version is 5, local router ID is 192.168.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 192.168.1.0 0.0.0.0 0 32768 i
Total number of prefixes 1
R1#sh ip bgp neighbors 10.0.0.2 routes
r> 192.168.2.0 10.0.0.2 0 0 20 i
R1#
router bgp 10
no synchronization
network 192.168.1.0
redistribute static
no auto-summary
BGP table version is 6, local router ID is 192.168.1.1
* 192.168.2.0 10.0.0.2 0 0 20 i ------->NO RIB FAILURE DUE TO REDISTRIUTE STATIC COMMAND
*> 192.168.2.0 10.0.0.2 0 32768 ?
Total number of prefixes 2
R1#
Solved! Go to Solution.
10-31-2017 11:58 AM
10-30-2017 04:15 PM
10-30-2017 09:10 PM
10-31-2017 11:58 AM
