RIP and authentication to unicast neighbor
bellocarico
Hi guys, I'm running into a problem trying to setup authentication in RIP.
First of all, I've successfully setup RIP between 2 routers using multicast (RIP v2) and key-chain.
Now, when I've changed the config from multicast to unicast, using the neighbor command + passive interface , the communication suddenly drops.
I've also noticed that this seems to be an authentication problem as (continuing in my example) removing the key config and ip rip authentication XXX the interface everything magically works.
Is the neighbor command compatible with key-chain?
R1 (only relevant config)
key chain PEEP
key 1
key-string gigi
interface Serial0.1 point-to-point
ip address 10.0.0.5 255.255.255.0
ip rip authentication mode md5
ip rip authentication key-chain PEEP
no ip split-horizon
frame-relay interface-dlci 501
R2 (only relevant config)
key chain BIP
key 1
key-string gigi
interface Serial0
bandwidth 64
ip address 10.0.0.1 255.255.255.0
ip rip authentication key-chain BIP
encapsulation frame-relay
no arp frame-relay
frame-relay map ip 10.0.0.5 105 broadcast
no frame-relay inverse-arp
Thanks to read!
ebreniz
Level 6
Level 6
Try key management.
Key management is a method of controlling authentication keys used by routing protocols. Not all protocols can use key management. Authentication keys are available for Director Response Protocol (DRP) Agent, Enhanced IGRP (EIGRP), and RIP Version 2.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca765.html#wp1001635
vladrac-ccna
Level 5
Level 5
could you give us the output of debug ip rip on both routers? (if possible filtering for this traffic only).
Let us know.
vlad
