Rip Version 2 configuration is gone
Kavarera
Community Member
i have 1 router that have 2 type of routing (static, ripv2) i did "do copy running-config startup-config" and "do write" but when i reopen the file, the rip configuration is empty there is nothing except the static routing... please help
Actually only router 3 has no RIP configured. To configure RIP is simple:
router rip
version 2
network 192.168.131.0
Using this file attached you can ping from one site to another.
Martin L
Do not use "Do" in command lines, Move to global config mode and save configs.  "Do" shortcut command was added recently.
are you transferring file from PT 7.x to 8 ?   Occasionally those will miss some lines.
Remember, PT is just a simulator of IOS not real thing.
Regards, ML
**Please Rate All Helpful Responses **
